Hiya,
Does anyone have a wiring diagram for Stoves 444445060? Serial is 51030359.
I’ve got to go to this one after someone else. Seems the wiring isn’t correct anymore.
Hiya,
Still looking for help with this one.
Previous engineer has wired up a new clock (or so I believe) incorrectly. I’m due to go to this on Tuesday and would appreciate any wiring diagram or technical bulletin on the machine if the clock has changed from the original.
Stoves used to put wiring diagrams actually on the outer case of the oven ( built in ovens) also check in the users manual sometimes they printed the wiring diagram in that as well, if not contact Stoves direct on 0871 222 2506 and Technical will email you a PDF wiring diagram, they have done for me before.
