I have a Stoves built under double oven. Model number 058505047. When the oven is switched on the cooling fan is not working. When I tested the cooling fan it is working fine. This means after the oven works for approx 45 minutes then turns off. Presumably because the housing unit is too warm. Do you have any suggestions?
