Re: Stoves oven door hinge removal.
hinge I can see is this one
https://shop.ukwhitegoods.co.uk/0829708 … door-hinge
if yes could not be easier to fit
lower door there is a screw half way up the door on the inside. either side of the inner glass. remove these 2 screw
close door almost and it should stay slightly open. get hold of outer door and lift off
undo oven from housing and slide out about 8 inches. just enough to undo 2 screws either side that hold hinge
reverse process and your there. can be a little tricky getting the door back on as the hinge stems have to go up the correct channel
