Stoves oven stuck on full temp
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves oven stuck on full temp
  • #59082
    Robodan
    Hi, hope you can help me out here.
    I have a stoves oven which once the oven is lit I cannot control the temperature. It either stays on what seems like full temp or I can turn it off.
    Any idea what the fault could be and is it easily repairable by myself or would I need a tradesman in?
    Thanks for your time
    #336750
    Re: Stoves oven stuck on full temp
    The oven temperature is controlled by what they call an oven thermostat. Whoever you choose to correct the fault that thermostat will need to be replaced.
    #336751
    Robodan
    Thank you for your response.
    Would you a rough idea on costs??
    #336752
    PGH13
    Gas or Electric?
    #336753
    PGH13
    The reason for the last question is that I had a similar problem with a Neff electric oven where the thermostat portion of the control had detached itself from the spindle so the setting on the dial was having no effect…..Just a thought; hope it helps
    #336754
    don
    Reading the OP question again.
    Robodan wrote:I have a stoves oven which once the oven is lit I cannot control the temperature.
    As no model number is given I have to assume it’s a gas oven, as such we would recommend a repair by a gas safe engineer as we are unable to advise on Gas repairs in these forums.
    Don
