Stoves oven temp problem.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves oven temp problem.
  • #26687
    dougiex
    Have a Stoves precision 1100 range style cooker. Problem is, occasionally the oven (electric, fan)burns things to a cinder in 10 mins when only set at 160/180. Then straight after it will be working normally again. This only happens maybe once a month. Thanks in advance, Dougie.
    #211076
    helo_75
    Re: Stoves oven temp problem.
    if its duel fuel, sorry we cant advise much
    stats probably faulty, but if its dual fuel, a corgi registered engineer needs to be called out to repair
    hope this helps
