stoves Q900 DRF DO
  • #37795
    dom999
    hi guys,
    while im trying to sort out my other machines thought i’d ask about my oven too,
    when the oven or grill has been use then turned off, its ok till about 5 mins later when it switches itself back on and flashes the green lights on the temp display, no heat, just fans and lights.
    any ideas, i know its probably going to be a stoves tech call out, although its not causing major problems, we just unplug it then plug it back in, then its ok—till the next time.
    thanks in advance,
    dom.
    #256409
    Re: stoves Q900 DRF DO
    Possibly some sort of temperature sensor deciding that there is an overheat and bringing the fans on…….
    wsts
    Thats a soft lock out if just the green light is flashing….. but be prepared for it to cost a fortune, if you ring stoves I believe you will be offered either a call out fee of around £85 + parts or £150 for a years insurance, if you are going to have the repair done then pay the £150 as the main pcb will probably be swapped and this alone costs over £150.
    #256411
    dom999
    thanks guys, dont think i’ll bother, its cheaper to just reset it…its not like its a major problem.
