Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Stoves Range cooker 200564131 sn11100828
- This topic has 7 replies, 4 voices, and was last updated 14 years, 11 months ago by
ray.t.
May 10, 2011 at 3:39 pm #62700
ray.t
ParticipantI have one of the above ovens that needs a main oven stat.
I had a part no from connect of 082359300 but it says its nla.
They say we need a kit with 2 stats, 2 switches and knobs etc.
Does anyone know if there is an alternative to the original stat, without swapping the whole kit.
Cheers,
RayMay 12, 2011 at 11:40 pm #351004TELL
ParticipantRe: Stoves Range cooker 200564131 sn11100828
No My Friend,
There is no esay fix for this, you have to get the conversion kit, as the thermostat is obselete. and the instructions do come with it to convert, the only thing is if its the main oven, or 2nd oven fault. You can convert the one you need and can keep the other half for a later date, or you could be lucky, and use the other half on another appliance, to gain little bit extra, on the delivery charge of the kit, but do hold onto it, it will be used.
TELL..May 16, 2011 at 6:47 am #351005ray.t
Thanks for that, I will get a kit and see how I go.
To change it does the top come off or do you get access from the side panels?
Thanks,
RayMay 16, 2011 at 10:34 am #351006TELL
top comes off,
TELL.March 1, 2012 at 3:37 pm #351007Johnnyboy
Re top the top comes off, is it straight forward? I have a main oven stat to replace and I have just been reading the nightmares of the kit, How does the top come off and does it interfeer with the gas side (main concern).
Cheers JohnnyboyMarch 1, 2012 at 6:08 pm #351008Lawrence
from memory,two press studs on the side of the hob top ,screws across the back and the deck lifts ,stat and switch right in front of you ,beware the new switch turns in the opposite direction to the original .
HTH
And no it doesn’t interfere with the gasMarch 2, 2012 at 2:40 pm #351009Johnnyboy
Cheers Lawrence, good to have been pre warned, might let the customer know before hand about the opposite direction thinggy though.
Cheers JohnMarch 7, 2012 at 3:05 pm #351010Johnnyboy
Cheers jobs a goodun,
