Stoves Range Cooker 444445367
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves Range Cooker 444445367
  • #94593
    rocker
    Been ask to change the door rollerball catches on ( both ovens) of this cooker…
    A photo has been sent to me..Looking at the picture I am assuming the middle flat strip of metal between both rollers can be removed as to gain access to change them…!!
    can anyone confirm if thats correct…If not please explain how its done…Cheers John
    #457791
    Seamy
    Re: Stoves Range Cooker 444445367
    It can be done from rear, with a long piece of metal rod and a magnet on the end ( the type of magnet used for tall oven door) attach the roller to magnet & push it in from rear, it then can be screwed from front when you go around, the magnet should hold it in place until screwed. Then pull firmly from back and rod & magnet should come off. Hope this helps you.
    #457792
    rocker
    Cheers Seamy for your help…never done one before as you can see. John
