Stoves Range Oven Door Catch Model 444440203
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Stoves Range Oven Door Catch Model 444440203
  • #103339
    Tom
    The Model Number is Stoves 444440203 A Range type cooker
    I haven’t came across this situation before where the left hand (swinging) door catch needs replacing. It is located in the centre of the cooker between the two ovens.
    I have had a look from the front and rear but access looks impossible. I am wondering if it has to be or can be accessed from the top. Hoping someone is familiar with this arrangement and can offer advice before I do any more stripping down.
    Thank you in advance.
    Tom
    #492773
    dont know with this one but some manufacturers do all sorts of silly things. there is a beko where to change the oven door hinge recievers you have to remove the oven cavity
    all you can do is look around. from the top maybe an option
    you can use string to get it into place and then juggle it to get the screws in
