Stoves s7-e900mf double oven.444448093
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Stoves s7-e900mf double oven.444448093
  • #97911
    mikehha
    Main oven won’t get to temp on fan oven. gets to about 150 then drops back to 90 and won’t go back up.but works fine when you put it on top and bottom elements and fan. So I’m guessing that the thermistor is okay as they should use the same one for convection and fan so any idea what could be the problem and if it is the pcb what’s the part number ta very much.
    #470084
    have you checked element. is it going open circuit when it gets hot ?
    mikehha
    I did think about that Dave but this is my sons oven and he has been trying to use it for a couple of weeks before he called me so I would of expected it to go open circuit and stay open or blow his trip.
    #470086
    well there is something odd happening
    as you point out the stat seems to perform ok on convection so that seems ok
    all you left with is a switch , or element fault
    also i assume this model is pcb controlled *have no tech to check) so have you looked for relay solder joint problems ?
    the only long shot i can think of is the sensor is being heated more by the fan oven
    Hollytree_Technical
    Is the fan definitely running? It would work fine with the top and bottom elements even if the fan wasn’t running but would just be a bit slower to heat, I have also regularly had people tell me that their fan is running when it is actually jammed solid and that they are only hearing the cooling fan not realising that it is a separate motor.
    Jem
    #470088
    mikehha
    All digital touch control facia so you could be right with a dry joint on the board . Looks like I will have to do the 50 mile round trip to go and strip it down .
