stoves1200dfa range cooker
  • #62470
    clockworkone
    regular customer reports dual element grill working intermitantly in small oven. seemingly works ok when on ie regulates itself ok :rolls: .is there a thermal stat or switch on this or does anyone have a wiring diag for these.i know i should have more info but am away and not able to get to it till saturday.paul
    #350203
    Seamy
    Re: stoves1200dfa range cooker
    Most intermittant problems i’ve come across with them is loose ‘link’ connections in terminal block. Post 44444???? product number when you get it as it’ll be needed to get correct diagrams etc.
    #350204
    clockworkone
    thanks for that seamy,going to have a look in morning.will post relevant no in morning.paul
    #350205
    clockworkone
    how easy are these to open up to get at control panel.paul
    #350206
    clockworkone
    got model no-059056306 and ser no 00201863.would appreciate any available tech info on this one.also is there a pattern part available for grill element 081561404.unable to get genuine here at moment.paul
