Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Strange AEG Wm fault
- This topic has 11 replies, 5 voices, and was last updated 16 years ago by
bagman.
March 13, 2010 at 3:31 pm #53222
bagman
ParticipantPNC 914 002 096 01
Bit of a strange one this.
Got called to the machine because it wasn’t spinning. It was obvious after a minute or so that this was due to a single item load, but I checked things out anyway. The first problem was the door lock ‘clicking’ open and closed several times before evntually locking. Customer said it had never done that before.
After checking that it drained/spun etc, I checked last fault in diagnosis mode and it came up with E41 (I think) anyway it reffered to door fault which had just occurred.
As I was only charging a callout fee due to NFF, I gave it one more quick fill/drain/spin test then went on my way after explaining loading procedure to customer.A short while later I got called back to the machine as it wasn’t working, all it was doing was counting down after being set to a program. No matter what program you put it on, it just counted down and did nothing (occasional drum turn).
I checked out diagnosis routine etc, and everything works from there. Last fault code was still the door fault.I thought to reconfigure the PCB, but there’s no sticker on the module with the code on.
So, anyone any idea or can anyone get me the configuration code so I can attempt to reprogram it?
March 13, 2010 at 6:40 pm #314944TheSpinDoctor
ParticipantRe: Strange AEG Wm fault
Hi.
The configuration code is: 261C169B15C1C7A4.
March 13, 2010 at 7:06 pm #314945bagman
Thanks, I think that’s one digit different from the current one I read off the diagnosis/configuration display. Hopefully that’s the problem 🙂
March 13, 2010 at 11:25 pm #314946boselecta
ParticipantHi bagman,
I will put money on customer has inadvertantley activated the demo mode.
The programmes run down in 1 second intervals.
Has caught me out before.What is your email address and i can send you deactivation process.
(could even be you inadvertanly put it into demo as you said you put it into test mode!)
March 14, 2010 at 12:04 am #314947bagman
Hmm, thats a def possibilty mate… not seen that before. Check PM for email address. 🙂
March 16, 2010 at 9:36 am #314948bagman
Hi boselecta, did you get my PM? If not I’ll send again, I could do with the deactivation routine.
Thanks in advance.
TrevMarch 17, 2010 at 7:59 pm #314949TheSpinDoctor
Check your PM’s mate.
March 18, 2010 at 8:56 pm #314950boselecta
Participantno didnt get any PM, try sending email again.
June 8, 2010 at 9:57 am #314951TeeMyob
ParticipantRe: Strange AEG Wm fault Diagnosis Mode
How do you get these machines into diagnosis mode?
I am going to one today. When start is selected, a few clicks can be heard but the red lamp simply flashes.
I am thinking possibly the interlock?
â„¢
June 8, 2010 at 10:27 am #314952Martin
TeeMyob wrote:How do you get these machines into diagnosis mode?
Model number would help….. 😉
June 8, 2010 at 1:15 pm #314953TeeMyob
Sorry
AEG
Lavamat 72630 Update
Model: 72630-W
S/N 12964479
PNC 91400209601I have managed to get it to start but the numbers on the timer simply countdown to 0 then zilch?
â„¢
June 13, 2010 at 2:54 pm #314954TeeMyob
Anyone? Please!
