Strange CI555WH fault.
Viewing 1 post (of 1 total)
  • #56509
    I went to this machine last month to refit the rusted outer door seal clamp and change the motor brushes.
    Got a call last week to say the machine was sticking mid cycle. Booked a call for last week but she rang back to say it was now working.
    Rang again this morning to say it was sticking again. When I called this afternoon she tells me that it has done this on the odd occasion a few times in the past 18 months, now she tells me. :rolls:
    I did notice that the machine appeared to have filled a little higher than normal.
    I drained it out and set it to TEST to check on the error log and it came up 001..faulty fill valve triac, this may explain the high water level.
    I then let it go through the 11 stage functional test, it failed to fill on step 2 ( fill from prewash valve) but it did complete all of the other steps perfectly.
    After checking both valves and all of the wiring I replaced the PCB.
    Now here is the strange thing.
    I decided to test the new PCB and it would not fill on step 2 of the functional test either.
    Also when I tried to advance it through the next steps it skipped from step 3 which should have been ‘fill from wash valve’ and went straight to step 7, clockwise motor action. ❓ ❓
    I ran the test three or four times and every time it skipped from step 2 to step 7, missing out everything in between. 😕
    I tested it on prewash and it is filling into the prewash drawer so I am now waiting for the customer to give it a try.
