strange fridge fault
  • #39084
    robbo1973
    fit a new compressor to a built in fridge there was gas in when old pot taken off,fit new one and gassed up running fine with thermometers in i went to feel the back of the fridge for frost and it had bulged out very evenly all over. the machines pressure has stayed solid for 5 days running on test cutting in and out.took it back and cust now says the shelves dont fit because of the slight bulge!!.has anybody seen this before and what could cause this???
    cheers chris.
    #261246
    Kentish
    Re: strange fridge fault
    Hidden evap type? Sounds like a blown wall and unstuck itself from the evaporator. Be surprised though if it was colling effectively though.
    #261247
    squadman
    A common problem on a lot of the Whirlpool intergrated units where the rear wall has seperated from the Evaporator,
    #261248
    robbo1973
    We have temp checked it and had a glass of water in the fridge to test as well.I have never seen this before and the cust says it wasnt like that before.
    #261249
    robbo1973
    is there a repair for this the cust says it is cooling fine.
