Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Strange issue with I-DOS on Bosh WAT286H0GB
- This topic has 4 replies, 2 voices, and was last updated 1 year, 9 months ago by
mark_r.
July 6, 2024 at 10:37 am #102846
mark_r
ParticipantHi, we have a Bosch WAT286H0GB that has worked well for a few years but has now developed a really strange issue. We have always used the I-DOS function and frequently use the “Mixed Load” program, however last week the I-dos button on the touch control panel (where you can select the detergent dose) sis dimmed as though I-DOS is “off” and pushing it to change the setting does nothing except beep. This “button” normally cycles through the dose level or flashes when the dispenser needs refillling. We ran a few tests and it appears no detergent is dispensing.
I would have assumed this was a fault with the sensor/pump in the detergent drawer, however on all other programs (e,g. “Cottons”, “Easy Care”…etc) we can change the I-DOS setting as normal – it would appear that only on the “Mixed Load” program that is stuck to “OFF”.
we have removed and cleaned the drawer but as the issue appears to be only with a single program can anyone suggest what may be going on here?
Appreciate the support
Mark
July 6, 2024 at 11:37 am #490749electrofix
Moderatorbosch are not very helpful in their manuals about this
it does say some programmes cant use I-dos but does not say which or list the programmes
it also says if you select certain things it will remember for all future washes
was wondering if you have set this programme to manual dose and you have to tell it to revert
only guessing really and i would ring Bosch customer service and ask
they do need to improve manuals to include more comprehensive info on these complicated machines
July 6, 2024 at 5:53 pm #490750mark_r
ParticipantHi Dave,
Thanks for the reply – the strange thing is we have had this machine for a few years and have used I-DOS on the mixed load setting pretty much all the time with no issue. It is only this program ithat seams to have the issue and weirdly the setting for fabric conditioner seams to work fine.is there a way to “factory reset” the machine? Had a look online but can’t seam to find instructions for 5ge touch control model.
thanks again
mark
July 6, 2024 at 11:42 pm #490751electrofix
Moderatorthere are resets for various machines but dont know if it resets customer perameters
I would ring customer service and ask the question first
July 7, 2024 at 9:18 am #490752mark_r
ParticipantOK will do and thanks for the advice….
mark
