Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Strange problem with hotpoint wmf760
- This topic has 6 replies, 3 voices, and was last updated 11 years, 9 months ago by
Mac558.
July 22, 2014 at 6:40 pm #81556
Mac558
ParticipantHello,
I put a normal cycle on my WMF760 and at some point it decided to stop. I was able to open the door, but it hadn’t rinsed the clothes. It was flashing an error F-06. I couldn’t really do anything, and the water wouldn’t drain.
Now when I try to do anything the led display flashes for a split second. It doesn’t seem to recognise that the door is closed, so I can’t seem to start a cycle. But when I try to start one it moves the time down to 00:01 and stops.
Sorry if I haven’t been able to explain it very well. The error message hasn’t been seen since the first time. Any ideas?
Thanks in advance for your help.
MichaelJuly 23, 2014 at 7:00 am #417015Martin
ParticipantRe: Strange problem with hotpoint wmf760
F06 = Faulty Door Interlock
July 23, 2014 at 7:15 am #417016Mac558
I haven’t seen that message since the first time. Is it common to see the error message only once?
July 26, 2014 at 2:20 pm #417017Mac558
Hello again,
I tried to drain the machine manually by opening the filter at the bottom. I was able to unscrew the cap about a quarter turn which allowed the water to drain slowly. I can’t seem to turn it any further or open it. The water drained quite slowly which led me to believe something might be stuck. Is there any way to actually open the filter? I can’t see how anything is moveable other than the screws to hold the hose in place.
ThanksJuly 26, 2014 at 3:22 pm #417018iadom
ModeratorRe: Strange problem with hotpoint wmf760
Should have checked those pockets. :rolls:
The only way to proceed without breaking the filter is to remove the pump completely to extract whatever it is that is stuck in there. Remove mains plug, lean it back against a wall or the units, ( get someone to hold it for you if you can). Remove the four screws and drop the pump down.
Prevention is better than cure, a few seconds checking pockets can save a lot of grief, it may not block the pump next time, coins and other hard metal objects can easily punch a hole right through the outer drum, wrecking the machine. 😉
July 26, 2014 at 3:53 pm #417019Mac558
Thanks.
I managed to unscrew drop the pump down (the bit with the cap) but I’m not sure how to actually open up the bit where the hose connects to the filter and drain. Sorry if I’m explaining myself poorly!July 26, 2014 at 4:18 pm #417020iadom
Take the hose off and you may be able to clear it, if not then completely remove the pump to allow you to clear it.
