Strange Washing Machine Fault John Lewis JLWM1402
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Strange Washing Machine Fault John Lewis JLWM1402
  • #73272
    TeeMyob
    Hello all,
    Can anyone help me please?.
    I have an ongoing problem with a John Lewis (Electrolux).
    Model: JLWM1402
    PNC: 914517102/00
    S/N: 60600082
    Set on program, appliance overfills, then pressure switch sends signal to empty washer. Program ends.
    Same on any wash or spin. Fils and fills, then empties, drain light comes on and the display simply flashes.
    Cannot fathom the problem unless it is one of those strange faults with a not so obvious solution.
    Please help?
    TM
    #386977
    deltra
    Re: Strange Washing Machine Fault John Lewis JLWM1402
    dont know this exact machine,some have anti flood switch in base(same as d washers) could be pressure pipe has hole causing air to escape and overfill? then tripping flood device?
    #386978
    TeeMyob wrote:Cannot fathom the problem unless it is one of those strange faults with a not so obvious solution.
    I guessing you have’nt accessed diagnostics? Interrogating the electronics for an error code is the way forward (saves scratching your head and sleepless nights).:wink:
    It has a regular EWM1000plus board so go to the Known Error Codes thread, or check your copy of the UKW Fault Code Bible, to know how to then access ‘Diagnostics’……gotta be the way forward for you. 😀
    HAPPY NEW YEAR!
    #386979
    TeeMyob
    Thanks for the replies.
    Could someone point me in the Direction of the said Bible please?
    Is there a link?
    Thanks once again TM
    #386980
    TeeMyob
    I Was going to order a heater.
    Turned out to be connector detached from the heater.
    TM
    #386981
    TeeMyob wrote:Could someone point me in the Direction of the said Bible please?
    http://www.ukwhitegoods.co.uk/downloads … 20v1.2.pdf
