Customer complains machine will not start, door lock symbol flashes and machine beeps five times.
Simple door lock fault thinks I 😥
Changed door lock but no difference. Checked doorlock to PCB and all other wiring, removed door lock from machine and activated by hand to eliminate latch problems to no avail.
Ran machine on diagnostics check and got an instant E-17, doorlock fault.
Removed facia to examine the control module for physical signs of damage. Releasd the top three plastic lugs but left the module in situ, just eased it backwards so that I could see all the contacts. No visual faults at all. Refitted the machine, resigned to possible control module fault. Tried machine once more and it worked perfectly with both the new and old door interlock. ❓
Left the machine for customer to test for a few days, does it seem feasible that by flexing the board I have released a sticking relay or similar??
