stuck on spin, no access to diagnostics Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › stuck on spin, no access to diagnostics This topic has 3 replies, 2 voices, and was last updated 20 years, 2 months ago by delta01. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts January 28, 2006 at 3:42 pm #15207 delta01Participant zanusie fj1254w power up shows spin mode only, works fine, will not navigate up or down, tried to access diagnostics but to no avail, suspect control unit, any suggestions. john January 30, 2006 at 9:29 am #162616 abbotsParticipant Re: stuck on spin, no access to diagnostics have you checked motor tacho? john January 30, 2006 at 3:10 pm #162617 delta01Participant Re: stuck on spin, no access to diagnostics no did not suspect tacho as motor action seemed fine, would faulty tacho cause syptoms described ? thanks for your reply, john January 30, 2006 at 4:05 pm #162618 abbotsParticipant Re: stuck on spin, no access to diagnostics no,probable not if spin is definateley ok,had a similar problem as this but the spin was disrupted. jk Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
