I’m trying to substitute a #47576-M01 for a #574-200-164 in a Hoover 500M
washer. Pls advise wiring pattern. The timers are different, but fit the same machine so the wires should all go somewhere.. My pick and put same didn’t work. thx.
Plan B: swap parts until it works — found stretched drive detent spring and stripped blue gear in gearbox-not the cam gear. Replaced both from other timer. almost 3 days work! Q. of the two, which one is the “early model” pls?
