“Surestop” water stop cock switch.
Home Forums Public Support Forums General Enquiries And Questions “Surestop” water stop cock switch.
Viewing 2 posts - 16 through 17 (of 17 total)
  • #472236
    if you use a motorised valve as opposed to a solenoid there will be no power drain unless valve is opening or closing
    wanji
    Aren’t they usually spring-return, like 2-port heating system valves? (Which by the way I discounted long ago as their working pressure is only 2 or 3 bar). I’ll have a look at motorised valves to see what’s available. If only 240V versions are easy to get I could incorporate an inverter; would be pretty low duty cycle and I’d power it down after activation..
