Sven oven
  • #8282
    anyone heard of a Sven oven? one booked for next week.
    #127812
    Re: Sven oven
    Yep
    What’s the fault you have got? and I’ll tell you what the part is you’ll need.
    I carry all the spares in stock for these ovens.
    tel 07961365484
    bryan
    #127813
    Re: Sven oven
    dunno, havnt looked at it yet, just wondered what it was. reported fault is dead oven, grill ok.
    #127814
    Re: Sven oven
    the fault then will be the potentiometer that is within the hob unit that is connected by an umbilicle lead to the oven assembly.
    the hob will have to come out to effect the repair and hopefully the installer has fitted it with a cooker hose(makes life a lot easier) 🙁
    once the hob is out remove 2 screws on each side ond the glass top will come off.
    once inside the potentiometer is in a case in the center front of the hob and the cover is secured by 2 phillips on the base of the hob,you will need to unsolder the old one one solder the new one ( only 3 wires though ).
    re assemble and there you go.
    give me a call for the potentiometer 07961365484
    bryan
    #127815
    Re: Sven oven
    Spot on Bryan. 🙂
    #127816
    Re: Sven oven
    Tis easy when you know how… 😆
    bryan
