Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Swan microwave SM2060 tripping RCB
- This topic has 7 replies, 3 voices, and was last updated 16 years, 4 months ago by
tiprat.
December 7, 2009 at 6:44 pm #50739
tiprat
Participanti could use a little help on this fault please.
Firstly i used to be domestic appliance engineer but moved onto high pressure cleaning equipment.
I know the dangers of capacitors storing energy, discharging capacitors etc etc. I used to do a lot of microwaves, but this one has a strange fault.New swan microwave SM2060W purchased by my daughter .
Used the microwave twice no problem.
Third attempt it tripped the RCD 30mA at the consumer unit.
Tested mains 13 amp fuse in plug, tested ok.
Brought the unit back to my house.
Removed cover, discharged cap, tested main Fuse 8amp on mains board.
Fuse was blown.
Tested insulation of high voltage components, transformer, magnetron,
checked diode, insulation of turntable motor etc.
All tested ok.
Replaced 8 amp fuse on mains board, tested and boiled a jug of water no problem, so took it back to my daughters.Told her it needed a good test.
Plugged the unit in, no problem controls all powered up, set the power level on the control board to 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} and the RCD tripped again.
The start button had not been pressed, just power level selected and the the power tripped, Brought round to my house again , checked it and the fuse on the main board had blown again.
rechecked all insulation etc etc, replaced fuse and works a treat.
Now my house doesnt have RCD whereas my daughters has.
Any one any ideas,
by the way she bought the item from ebay from a seller with a good reputation but is now no longer trading so sending it back as faulty is a no go. That would be too easy, kids dont you just love em!
cheers
December 9, 2009 at 5:17 pm #305798tiprat
ParticipantRe: Swan microwave SM2060 tripping RCB
any ideas on this one folks???
pretty please..
December 9, 2009 at 5:19 pm #305799tiprat
pretty please..
December 9, 2009 at 9:58 pm #305800Penguin45
Public forum, Tiprat – no-one’s going to discuss a safe method of dealing with 4.5kV.
Penguin45,
Moderator.December 20, 2009 at 6:36 pm #305801tiprat
ok fair enough, used to dealing with 12 Kv , but you arent to know that i am competent from a request from a forum. which i agree with totally! electricity kills….. Colourless odourless invisible but boy can it bite.
so if i were to test the microwave with the high voltage side disconnected at the transformer and the problem persist would i then get help on this matter?
any replies welcome, cheers,
andyDecember 20, 2009 at 7:14 pm #305802timdowning
I can’t help with your problem but surely its not worth the risk or stress in trying to fix it.
Cheapest on-line price £39.
Tell me to shut up if you want. 🙂
December 21, 2009 at 8:33 am #305803tiprat
cheers for that , i know its not worth the hassle but i’m that sort of person. rather get to the bottom of it no matter how long it takes..
merry christmas 😀
December 26, 2009 at 7:23 pm #305804tiprat
cheers for all the help and advice its now working as it should.
Cheap flimsy plastic moulding on monitor microswitch retainer.
about a millimetre of freeplay on it, using it round at hers it must have been been moving slightly causing it to do what its supposed to do, put a short on it.Slight adjustment, replace microswitch and hrc fuse, sorted.
i’m very tenacious and wouldnt let it beat me.
