Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Switch on my Whirlpool Generation 2000 oven
- This topic has 7 replies, 3 voices, and was last updated 17 years, 9 months ago by
Geordielad.
June 27, 2008 at 8:24 am #37688
Geordielad
ParticipantI have had a whirlpool Generation 2000 oven for around 4 yr. Model number G2P 62F/SS.W hen i switch it on i get power to the oven but pressing the button to get the cooker to switch on wont work. All it as in the window is the letters s.t.o.p and it wont go off. Any ideas will be most welcome. Geordielad
June 27, 2008 at 1:34 pm #256056johnmac11
ParticipantRe: Switch on my Whirlpool Generation 2000 oven
Turn the main oven knob to the off position
Press small centre button till digits lights up in bottom r/h corner of display
Turn right hand knob to adjust to correct time
Press centre knob to set
Oven should work normaly nowJohn
June 27, 2008 at 2:28 pm #256057Geordielad
Thanks John for the reply, the problem is when I press the centre button I cannot get the digits to come on any more. It as been working fine but now I have the problem of it not clicking in to start the oven .
June 27, 2008 at 4:05 pm #256058johnmac11
If you cannot feel the button depressing them the button switch is knackered, if it does press in but wont change the settings then it is usualy because the oven mains has been switched off which will bring up stop” in the display when switched back on. To get it to move off stop the main oven selector switch has to be in the off position and what i wrote above applies.
If the button switch is jammed post up the 12nc number which is on the r/h side of the door frame and I will get you the part number. 12nc number starts with 85….. and is 12 digits long.
JohnJune 28, 2008 at 8:58 am #256059Geordielad
Thanks again for taking an interest in my proplem John. The button does depress but it wont come off stop. The number you asked for is 854183815020. In the last three weeks it as been acting up by not coming off stop, but with patience I have got it to work. Now it wont work at all. One further question if you could answer it for me please is when we finish with the oven we switch it off at the mains is this the right thing to do or should we just leave it on the neautral button at all times.
GeordieladJune 28, 2008 at 9:57 am #256060Geordielad
John I have took the cooker to bits, cleanend the parts and put them back together and guess what? it is working. Thanks for the advice, but would still like to know if it is best to leave the cooker switched on rather than taking it off at the mains.
GeordieladJune 28, 2008 at 1:16 pm #256061johnmac11
just leave it on otherwise you will need to set the clock every time you use it.
John
September 4, 2008 at 5:49 pm #256062johnb83
Hi John, Geordie lad,
I have the same issue, do you know if it is easy to take aprt and fix / clean? The oven turns on fine and I can press the button in ok but nothing happens.
Many thanks,
John B
