Dishwasher overfilling and so does not drain all the water out.
Ive replaced the reed switch on the air chamber but the problem persists.
Could it be the air chambre its self?
As you can see from the picture the water level is up to the spray arm.
as far as I can see on the spares listing there are no other sensors for water height
as long as the reed switch wires have continuity back to the board and the connectors are not corroded I would suspect the board. It may be the part of the board that counts the water in or the triac that controls the valve.
if you open the door when it fills for the second time a I assume it stops.
