sy36 oven
  • #78461
    clockworkone
    Fault reported was oven shut down 2 days ago.completely dead no display etc. Turned on this morning and worked fine for 25 min.Turned on this eve and packed in after 15 min.can anyone tell me will thermal cut out on this one reset like this or is it one shot system and once it goes once its gone.Paul
    #405777
    Re: sy36 oven
    A TOC shuts the oven down but not the display. So I’m thinking power supply problem, what say you?
    #405778
    Criscold
    Re: sy36 oven
    Looking at wiring diagram I think you will find this oven has a TOC in the live feed and looks like it would shut down the display as well, part number C00089573 or wiring on terminal block.
    #405779
    johnnyj
    Re: sy36 oven
    They were changed to a higher rating due nuisance tripping shuts everything down when they open, i think it was about 10’c higher the later ones.
    #405780
    clockworkone
    Re: sy36 oven
    Many thanks for all your’e replies.Sounds like t/limiter fault but will check connector box as well..paul
