t/bendix aw1001 not starting Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › t/bendix aw1001 not starting This topic has 2 replies, 3 voices, and was last updated 13 years, 11 months ago by jenson. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts April 25, 2012 at 3:00 pm #69139 jensonParticipant hi,you can select program ok,then press start,the wash and start light lite up,with in secounds tho the lights go out an end light is lit,which flashes 4 times,im off to try a interlock but not confident thatl fix it April 25, 2012 at 6:21 pm #373837 SeamyParticipant Re: t/bendix aw1001 not starting Error E40s are door interlock related. Check cabling connections to p.c.b & interlock. April 26, 2012 at 10:41 am #373838 leavemetogetonwithitParticipant Re: t/bendix aw1001 not starting If no luck with lock, check for low insulation / damp. Try with motor unplugged. Mike. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
