T/Bendix DH101 leaks, prod #911831021!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries T/Bendix DH101 leaks, prod #911831021!
  • #21968
    effzedarr
    Oh God another D/Washer. M/C leaks lhs, take off side panel put m/c on rinse & hold prog ,all ok! Put on #2 wash m/c fills stops ,starts to wash but at the same time water pours out of a slot part way up on the metering tank towards the rear! Then once m/c has been running for about 30 secs & the water level has settled all is ok 😮 .
    Does this mean a new tank assy or does it need a mod kit fitting as the one mentioned on the TDS disc ,if so is it a prat to fit as it looks? :rolls:.
    many thanx Chris.. 8)
    #193200
    Re: T/Bendix DH101 leaks, prod #911831021!
    You want 1524624-03/6 – another one of what you’ve got. List is about £55 – lovely little earner.
    effzedarr
    That be one of them there metering tanks then?!
    thanx Chris, from Chris.. 8)
