T/BENDIX DH200
  • #26829
    machineman
    Hi all dishwasher going all the way to the end without heat ,checked the mod relay for dry joint and heater ok,any thoughts.m
    #211531
    goosegreen
    Re: T/BENDIX DH200
    Hi Machineman,
    Had the same problem with a Zanussi D/w couple of weeks ago,No visable sign of damage on the PCB, Heater circuit ok but it turned to be the board in the end. Not a cheap repair! 😯
    Goose
    #211532
    machineman
    cheers goose the heater did come on for a few mins had this horrible feeling it would be the board.why does it go all thro the prog without heat , you would think it would stick on a heat pause? m
    #211533
    goosegreen
    Re: T/BENDIX DH200
    Thats what confused me as usually the program would stick at the heat phase 😮 and the one I went to also heated for a few minuets then stopped. I Think when I fitted the new board it again heated for few mins and the stopped but after a short time it started to heat again and finished the prog.
    Goose
