Hello,
I am looking for a coil to fit an older Kenmore branded/Frigidaire built front loader washer. This washer originally had a Sole motor in it. That motor went south. I found another motor, but it is an AEG motor that has a bit different sized tacho than does the Sole. Unfortunately the tacho coil on the AEG is open. I can’t swap the tacho because of the size difference.
Someone might have a coil laying around or know where to source one?
The tacho coil I’m looking for has a 32mm outside diameter and a 20mm inside diameter. It is 13mm thick/tall. I don’t care what type of connectors it has. I don’t care what the exact resistance is of the coil as long as it HAS some (not open).
Thanks!
