Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Tacho coil dropping off
- This topic has 13 replies, 8 voices, and was last updated 16 years, 11 months ago by
andy_art_trigg.
April 24, 2009 at 11:26 am #45211
andy_art_trigg
ParticipantI’ve seen quite a few tacho coils dropping off and always manage to refit them okay. Is the clip that holds them in place generally available as a spare part? I’m thinking specifically of a candy CAW1010 whose owner has contacted me saying they have been told they must have a new motor because the tacho coil keeps dropping off.
April 24, 2009 at 11:46 am #284053bazza500
ParticipantRe: Tacho coil dropping off
I stick a spurt of superglue on them. Seems to work.
April 24, 2009 at 7:20 pm #284054LJDomestics
why do they keep dropping off?.. do u check the brushes when this happens?
April 25, 2009 at 8:33 am #284055electrofix
ModeratorRe: Tacho coil dropping off
i never use superglue if you ever want to remove it yu cant
i use debor works a treat its flexible and can be removed if necessary
April 25, 2009 at 8:37 am #284056bazza500
why would you want to remove it?
April 25, 2009 at 9:09 am #284057electrofix
i carry debor use it on screws as an antishake or to screw tacho magnets into zannussi machines if i used superglue it may go off bfore bolt is tight or fully home superglue is one of those last resort answers and i dont want to spend rest of the day with my thumb and forefinger stuck together lol 😆
April 25, 2009 at 1:37 pm #284058Phidom
I tend to use silicone sealer for all those kind of jobs.
April 25, 2009 at 5:04 pm #284059Specialist01269
LJDomestics wrote: do u check the brushes when this happens?
Why?
April 25, 2009 at 5:06 pm #284060LJDomestics
seems to be a lot of vibration if they just “fall off” ive not known nothing fall off for nothing.
only ever found a tacho hanging once on a whirlpool… brushes were well down!
April 25, 2009 at 5:26 pm #284061Specialist01269
Seems to be a pretty common problem on modern machines, they don’t stay attached like they used to. Have to say Never had 1 due to worn brushes but will wait & see.
April 25, 2009 at 5:29 pm #284062LJDomestics
Brushes mite of been a coincidence… i persumed that it had fell off due to vibration ( badly spinning ) from low brushes, had i come across many tacho faults like this i could maybe then persume different… 😛
April 25, 2009 at 9:39 pm #284063leavemetogetonwithit
I don’t use debor in that place. It’s only a small risk but once cured debor catches alight it carries on burning! I don’t remember how I learnt this but I must have done some sort of experiment at some time in the past 😳 .
Mike.May 1, 2009 at 9:01 am #284064electrofix
@ leavemetogetonwithit
wow would not like to see a plastic tub if the motor got that hot lol 😆
May 1, 2009 at 10:05 am #284065Simon46
Magnet comes unscrewed and forces coil out of motor.
S. -
