Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Takes water, drum turns couple times. then stop?
- This topic has 9 replies, 4 voices, and was last updated 16 years, 7 months ago by
vito.
September 2, 2009 at 8:19 pm #48276
vito
ParticipantPower comes, takes water, drum spin about three times then stop. If i try to put program to pump water out nothing happens. It make same thing in every wash program, is it pcb fault?
Thank you!
September 2, 2009 at 8:26 pm #296152helo_75
Participantand the machine make/mocel number would be?
September 2, 2009 at 8:30 pm #296153vito
ParticipantRe: Takes water, drum turns couple times. then stop?
Its Upo Maxi 510. These are sale in sweden and finland, and maybe other lands.
September 2, 2009 at 9:39 pm #296154iadom
ModeratorRe: Takes water, drum turns couple times. then stop?
That’s a very tiny picture vito, very difficult to guess if it is similar to anything sold here in the UK, is it popular in Finland?
September 2, 2009 at 9:49 pm #296155vito
Yes it is very popular in finland. Better picture. Upo mark was originally made in finland, but this is made in eu somewhere. I know that in these upo models are very often PCB problems. Couple times drum turns and thats it, and if i put spin program it doesent push water out, its same in all programs, takes water 2-3 turns and then nothing happens.
September 2, 2009 at 10:09 pm #296156iadom
Not seen anything similar to that, the base looks a bit like an Amica machine. Any suggestions from here would be pure speculation to be honest. A picture of the inside of the machine would give up more to go on.
The electronics in Indesit made machines are not the best but that doesn’t look like an Indesit, could be Antonio Merloni product, also prone to PCB faults. :con:
September 2, 2009 at 11:10 pm #296157vito
Is it possible that brushes are too bad, but why that doesent even pump water out when i try?
September 2, 2009 at 11:18 pm #296158Penguin45
It’s a Merloni-built product. The fault you describe is not “logical” – this would point to the pcb being the problem (As usual!). Check the pcb for burnt/cracked solder joints and make sure that the connectors are very tightly connected to the pcb.
There is the a number on the pcb starting 546——— . This is the part number if you wish to find a replacement.
September 8, 2009 at 2:06 pm #296159vito
Something is stucked to drum, is it possible in this model open those three plastic sieve or do i have to take heating element out?
When i have laundry something is keeping noise inside but without laundry its normal.
I have 2 of these machine and im thinking this model is very crap machine.
September 8, 2009 at 9:18 pm #296160vito
Oh boys that was full of hammer nails and everything. I have ever seen so much shit in washing machine. I didnt know that in this model drum basket is medal and thats why all the nails and other shit makes that sound more heavier.
I think this is not so bad model only PCB is poory protected.
This is another machine not the same in first post.
