Taking a Long time to go through cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Taking a Long time to go through cycle
  • #8868
    Goldie
    Why is my hoover classica taking over 4 hours to do a cycle when it should only take one. It has recently been moved and now it does not work correctly.
    #130839
    Re: Taking a Long time to go through cycle
    Goldie,
    Check all the obvious things first as it was working OK before 💡
    Make sure the hoses are connected correctly and that the water is turned on and flowing. Check to ensure the drain hose is not kinked and is clear to pump out. Run a ‘test’ cycle without clothes to see it fill/wash/drain/rinse and spin.
    Any problems?…Get back to us with more specific info (Including the actual MODEL Number – most important 😉 )
    Goldie
    Thanks for that will check and let you know what happens.
    #130841
    SparkyP
    Hi Goldie,
    One thing to check is that the drain hose is not pushed right down to the bottom of your waste trap. If it is this will cause siphoning. It is quite a common thing when people move the machine and then refit them . If your waste is connected under the sink then disregard the last advice.
    Good luck.
    Sparkyp
    #130842
    Goldie
    Thanks for that we have checked that and no it is not pushed right down but the dial just doesn’t seem to be moving round we have watched it for a while and the dryer works fine.
    #130843
    Goldie,
    It’s probably not heating on the wash cycle in that case? It will just continue to wash forever because the thermostat is not getting a signal to move on. Turning the dial to the start of the rinse cycle, it will continue normally I expect 💡
    You’ve still not disclosed that all important MODEL number though ❓
    Goldie
    Sorry!! The model number is Classica A8604 but thanks for your help with the suggestions you have made we seem to have sorted the problem it’s working OK now. Thanks for your help. 😀
    #130845
    So what was it then? We’re all itching to know……..
    Goldie
    We pulled out the washing machine and did a wash and it worked fine so we think the pipes must have been getting crushed when we put it back in so we ended up pulling out the dishwasher to make sure this didn’t happen again when we pushed it back in as it was quite a tight fit.
