Tauber B600DG (built in oven)
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Tauber B600DG (built in oven)
  • #30463
    rocker
    Need a grill element for this oven, connect is special order 2 to 4 weeks delivery, can anyone please advise where I may buy this part.
    Cheers John.
    #227296
    mike1
    Re: Tauber B600DG (built in oven)
    what is the connect part number
    #227297
    rocker
    Mike
    connect part No 5045171918247
    John
    #227298
    mike1
    john
    i would order it from baumatic direct,there spares no. is 0118 9336 922
    and the part no. is x1170000706.
    mike
    #227299
    rocker
    mike 1
    rang baumatic, this part will not fit this oven, as the part I need is only a single element push fit..teres are twin elements.
    cheers John.
    #227300
    mike1
    sounds like you need bmtx1170000707 in stock at connect £22.02
    mike
    #227301
    rocker
    Mike, thanks for your help,but the part I need is a plug in only element..
    ie. plugs into a 3 pin socket, neff & bosch use same type!!
    Cheers John
