I have a TB DH102.
Doesn’e seem to be fillign with water….I turn the dial to a program- machine makes a noise but when I oipen it no water!!!
I have seen about the blockage in IWMS, so I tried adding some water directly inside the machine. It worked I think for about 2 minutes, but then stopped as usual with a humming noise. The selctor dial remains then.
I looked at the machine and it seems to be the non-blue tube type.
I tipped the machine on its side to see if I could access any of the IWMS pipes mentioned but couldn’t see what I should remove/clean. There seemed to be a large white cover stopping me accesing a lot of things.I’m usually pretty good with DIY things so if anybody had a basic guide of what I should do I would really appreciate it.
Cheers!!
