T’Bendix AW1400W no motor action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries T’Bendix AW1400W no motor action
  • #9809
    Seamy
    Been to look at an Tricity Bendix AW1400w washing machine 2 years old, found it to have a sock jammed betweeen drum & outer tub. Removed obstruction, drum free, checked motor, brushes ok & motor seems to test ok for resistance, toc ok & field coils ok. Me thinks probably duff electronic control board, is there a fault sequence stored on these & can they be reset?
    #135951
    Dave_Conway
    Re: T’Bendix AW1400W no motor action
    It should throw up an error code according to TDS, it also depends on whether there is an LCD display, horizontal or vertical buttons, the latter have no display so it’s a light sequence code. 😕
    I think I may just as well send you the whole document 😉 86 pages of it 😯
    On the way.
    #135952
    Seamy
    Its the model with vertical buttons, if that helps Dave.
