tc480w belt snapped
  • #15977
    delta01
    customer says approx 2 yrs old, am going to it thursday,any known cause premature belt failure on these models, if my memory serves me well some zan. belt failures down to front felt bearing / seal being worn, or is it just poor belt quality ?
    #167053
    Re: tc480w belt snapped
    More likely the customer has lost track of time and it’s a lot older than she says.
    #167054
    aqualectric
    When customer doesn’t clean the filter regularly, lint gets in between the front bearing seal and the drum; rolls up into a lump and can brake or completely jam the drum. Had this several times. Always worth removing the drum and cleaning round the seal. Also check for sticky or split jockey pulley. 😉
    Phidom is right; her ‘2 years old’ for a TC480 is a little ‘economical’ shall we say?? 🙄 If its got the electric fan on the back in place of the ‘crossover’ green belt it’s probably 10 – 12 years++!! 😯
    #167055
    delta01
    thanks for suggestions,will implement them.
    john
