TCP21/1x
  • #53930
    aqua_serve
    Can anyone help with part no. for the lower fan on this model? Seem to be having problems locating it, the only one I can find is 91941364 but I’m looking for the one below this (the one inbetween the lower element).
    Many thanks,
    Mark
    #317785
    Re: TCP21/1x
    91940263 is fan motor complete for fan oven (ring element) for model TCP21X which I should think would be same. See Connect mediator for exploded diagrams. (Home page > left list > “cookers and ovens” > Candy > select model > select “mediator” tab.)
    Mike.
    #317786
    aqua_serve
    Re: TCP21/1x
    Many thanks for the fan part number, ordered it without seeing an image, whoops! Turns out to be the wrong one.
    The details from the oven are
    Model: TCP21 /1x
    Code: 33700127-07401320
    If anyone can shed a little more light on this I’d appreciate it.
    Mark
    #317787
    Re: TCP21/1x
    Suggest phone call to Connect to sort it out and at same time get them to accept return. If you go through mediator, I’m sure it will come up with same part.
    Mike.
