TCR2 noisy when it heats up
  • #33703
    Seamy
    Got a customer complaining of a Creda TCR2 tumble dryer that has a curiuos scraping sound only when it heats up.
    I suspect its rubbing off back. Is there any modification for these, do you have to change the felt bearing at back & shaft & washer or someting?
    #239725
    Re: TCR2 noisy when it heats up
    Has it got the two plastic wheels at the front? If so they want throwing away. There is a kit to replace them complete with front & rear seals and four plastic bearing pads. Not sure of the number for the condenser dryer but I use the 1703080 V4 shaft kit for the vented dryers, it has all the bits you need.
    Seamy
    No wheels, its a vented jobby, the stretch belt pulls down so hard on drum that it twists when going clockwise & scrapes off back wall of dryer.
    Damn bad design of tumble dryer, most of them shear off shaft after a year, i saw nothing wrong with the old style drive system with, belt tensioners
    #239727
    TCR 2 is a condenser dryer. 😕 ❓ 😕 Do you mean a TVR2 😆
    There is a new drum assy to cure the vented dryer scraping problem, it has a rounded profile at the back.
    There is a TVR2 dryer BTW. 😉
    Seamy
    Cheers. it is a TVR2 & pray tell how much will this drum cost?
    #239729
    Not to bad, around £36.00 ex vat list price.
    Part no C00145650.
