Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › TD4212W not heating URGENT
- This topic has 15 replies, 3 voices, and was last updated 15 years, 4 months ago by
Nicky321.
December 2, 2010 at 4:54 pm #59311
Nicky321
ParticipantZanussi TD4212W Tumble drier, drum turning but no hot or warm air being produced, can you help?
December 2, 2010 at 5:45 pm #337654iadom
ModeratorRe: TD4212W not heating URGENT
A good place to start, after you have unplugged of course, is the small thermostat located inside the door surround near the top. Held in place by two small screws. Lie on your back and stick your head inside to observe.
You will need a megger or multimeter to test this component and also the heating element if this stat is not faulty.
PS. EVERY call is urgent..or so I get told several times every day. 😉 If its not that then its “an emergency” :rolls:In my book, serious illness, accidents or worse are emergencies, not failures of domestic appliances. 😛
December 2, 2010 at 5:55 pm #337655Nicky321
ParticipantRe: TD4212W not heating URGENT
iadom wrote:A good place to start, after you have unplugged of course, is the small thermostat located inside the door surround near the top. Held in place by two small screws. Lie on your back and stick your head inside to observe.
Thankyou.
Have checked the thermostat inside the door and like the other two on the heater element are closed. What should the readings on the multimeter be?December 2, 2010 at 6:19 pm #337656iadom
All stats should be closed circuit.
Three different types of element used, resistances vary from 33 Ω to 78Ω dependant upon which type of heater is fitted and if you are testing one side of the element or both together.
If it is faulty then it is often possible to see the break in the element.
December 2, 2010 at 6:27 pm #337657Nicky321
Cannot see any breaks in the element, I have the model number TD 4212W and serial No 148 01882 if this is of any help
December 2, 2010 at 6:48 pm #337658iadom
The Pnc or product number is required for any detailed parts or technical info.
Once you have tested the stats and the elements plus the wiring from the element to the timer etc its really as much as you can do without throwing parts at it. 😥
December 2, 2010 at 7:18 pm #337659Nicky321
Product No is 916760103 01
December 2, 2010 at 8:48 pm #337660iadom
So have you tested the element?
If that is OK then from here on in it is mainly guesswork or time to get someone in with full access to technical information. 😉
December 3, 2010 at 9:06 am #337661Nicky321
Right the element is checked and working 😀 The thermostats are closed 😀
its a matter of checking everything else now, surely it not gonna be too serious a problem, there doesnt seem to be much in there.December 3, 2010 at 10:32 am #337662iadom
Too true, this games a real doddle and no mistake. :rolls:
Not sure what you mean by the heater is checked ‘and working’, if its working then it should be getting hot. :con:
December 3, 2010 at 10:41 am #337663Nicky321
My other half connected a lead to the heating element and it got hot. No idea why it is that when its connected to the dryer only cold air blows through.
December 3, 2010 at 10:45 am #337664iadom
Nicky321 wrote:My other half connected a lead to the heating element and it got hot. No idea why it is that when its connected to the dryer only cold air blows through.
An exceedingly foolish and unnecessary thing to do. 😯
I fear that if you are going to indulge in such dangerous practices then I can offer no further help. 😥
December 3, 2010 at 10:59 am #337665Nicky321
My husband is an electrician, and his colleague checked it, he is also a qualified electrician and have beenfor over 30 years.
December 3, 2010 at 11:20 am #337666helo_75
Participantok, we’ll all bear that in mind when we want to rewire a house
so good he must be, doin live testing and stuff
if its simple, with nothing much in there, why is he asking for help?
no need to be bullish about it, the facts are, he hasnt found the fault
December 3, 2010 at 11:23 am #337667Nicky321
OK sacarstics, Actually they are qualified to rewire houses and work all over the UK contracting, they dont fix tumble driers daily!
