My TDC32 is running with no heat, I have checked the Thermostats on rear (nr Heater) and OK, even placed wire links bypassing thermos, still no heat. One of the threads I read previously mentioned a Thermo in the door, can anyone tell me where it is and how to get at it.
Can remember name now but thanks for tip on how to reset thremo by drilling ‘cos I pinged it when removing.
Penguin45, thanks for the info. I got a thermo from a Hotpoint Service Engibeer who happened to be visiting neighbour. All functioning correctly now.
Slight note for others doing the same replacement: The spade connectors will usually spring back into the top of the dorr when you remove the Fluf Switch, you can get at them by removing the top of the dryer (2 screws at rear and slide forward).
