TDC60S dryness module
  • #23743
    Simon46
    Fitted a new one for no heat fault. Pressed on schrack relay during operation confirmed intermittent operation (buzzing and clicking and light coming on/off).
    Replaced module now cust says dryer runs too hot and doesnt finish cycle.
    Anybody had faulty out of box new module? (1702136)
    Regards
    S
    #199197
    Re: TDC60S dryness module
    The fault sounds a little different this time though? 😕
    Probably now rather than a fault Module, the connection between module and contact brush is at fault?
    #199198
    Simon46
    Thanks Martin. Also the programmed dry setting doesnt finish and the timed has no tumble cool. 😕 has anybody got a wiring diagram for this in the unlikely event a connector may have been put on incorrectly?
    Simon
    #199199
    Simon46 wrote: has anybody got a wiring diagram for this
    #199200
    Simon46
    :worthy:
    S.
    #199201
    Simon46
    Replaced module again but also found Earth high resistance (varying)from black wire (module)to cabinet. Stacked on WMA (vibration?).
    Found machine screw loose that earths black wire to module 😮 . Stripped thread on cabinet(painted).
    Made new earth and scratched paint away. Fingers crossed.
    S.
