TDL 60 poor drying
  • #59252
    delta01
    not familiar with this one as its a sensor type i noticed when set on timed dry it the low heat light comes on is this right , the heater works but have not yet checked both halves of it also is there an exhaust stat ?
    any help appreciated
    #337484
    Re: TDL 60 poor drying
    You know, I don’t think I have ever seen a TDL60, loads of TDC60’s but not one of the vented Ulitima machines. They were only produced for two years though.
    The TDL manual doesn’t mention it but the TDC machine which has the same control system does only run at half heat on the timed cycle.
    Usual cause on the condenser one is a blocked condenser so air flow, loose fan etc needs checking, also make sure the copper braided brush is in good contact with the band round the drum.
    The small high temp stat can fail intermittently, its located inside the door surround, just past 12.00 o’clock.
    jim.
