Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › TDS disc
- This topic has 7 replies, 5 voices, and was last updated 20 years ago by
iadom.
March 15, 2006 at 4:41 pm #16384
ModeratorWhen I install this software, I always go for the full install. however when I come to use it, after identifying the model, I always get prompted to insert the TDS DVD to proceed further.
I have checked on my hard drive and all of the PDF files are already on there. I may be being a bit thick here, but is there some way I can use TDS without having to put the disc in the PC every time?March 15, 2006 at 5:12 pm #169616Dave_Conway
ParticipantRe: TDS disc
On the main page, click on the spanner icon near the bottom right, you can map the drive letters in there.
It should do it on install but more often than not it doesn’t 😕
Also follow the path to where the application runs from
program files/electrolux part/tds offline/install I think from memory.Edit the *.ini file in notepad making sure the drives all = C:/ or wherever the files are located 🙂
March 15, 2006 at 5:15 pm #169617iadom
ModeratorRe: TDS disc
Thanks Dave, I thought there had to be some point in installing all that lot. 🙂
March 17, 2006 at 3:52 pm #169618robbra
What is the TDS disc for and where can I get it if needs be?
RobMarch 17, 2006 at 4:24 pm #169619Dave_Conway
It’s the Electrolux tech disk, part number 506006065003.
Connect usually have it in stock.
March 20, 2006 at 5:44 pm #169620robbra
Thanks Dave
I will order one
RobMarch 20, 2006 at 11:06 pm #169621electrofix
i use a cd rom emulator this allows me to load and image of the complete cd on the hard drive and the computer treats it as a cd rom
i now have 3 ghost cd roms on my system and the system will take more if i can find more disks to run. they can be dvd or cd roms
this also means i can run one cd on several systems
hope this helps
dave
May 17, 2006 at 6:52 pm #169622dpm
ParticipantA quick bump for this thread with how-to-get info, and a reccommendation.
If anyone is in this trade and doesn’t have a copy of TDS, get one now! It’s a superb resource. Wearing my other hat, I work with lab. equipment; guys, I see equipment at £5k, £10k and more and the quality of the service technical and faultfinding info for these £300 machines is WAY above that available (even to agreed distributors and agents).
I’m happy to admit that I’ve learned a HELLUVA lot about the most recent technology by reading some of the technical info on this disc. Hats off to ‘Lux!
