Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › TDS Disk
- This topic has 19 replies, 5 voices, and was last updated 20 years, 1 month ago by
gegsy.
February 14, 2006 at 9:08 am #15628
gegsy
ParticipantHi
Is anyone else having problems with this disk>?When Its run it eventually the activex bar at top comes up and asks to download a file. Downloaded that and ram it does nothing with it.
If you run it again the activex bar comes up again.
PC has Win XP SP2 installed. Will run on laptop using ME, used to run on the XP one.Thanks
February 14, 2006 at 10:53 am #164295iadom
ModeratorRe: TDS Disk
Is this the 2005 disc? I had this problem with it a while back and did a complete re install to cure. I’m on XP and have both Acrobat 7 & Acrobat 5 from the TDS disc on my system, most of the time it runs OK.
February 14, 2006 at 7:29 pm #164296gegsy
ParticipantRe: TDS Disk
Thanks Jim
It the office thats havin the problem will check tomorrowThanks Jim and for email 😉
February 14, 2006 at 9:00 pm #164297iadom
If I remember I also stopped Acrobat from searching for, or downloading updates. I seem to remember it was the last update to Acrobat 7 that caused the problem. you may need to roll back system restore if you have allowed Acrobat 7 to update.
February 14, 2006 at 10:03 pm #164298gegsy
Chers again will try that 😉
February 15, 2006 at 9:33 am #164299gegsy
Hi Jim
Its TDS Offline GB2004 (DVD)
DGS-TDS-N 01/2004
Cheers
GregFebruary 15, 2006 at 9:55 am #164300iadom
Hi Greg, mine is version 2005, I am now almost sure the problem you have occured on mine as soon as I allowed Acrobat to update itself a few months back, I even posted on here at the time and others had a similar problem. Mine is now working fine after un installing TDS, Acrobat 5 & 7 doing a registry clean up, then re installing everything.
Just make sure that you un tick the auto update/update promt options in Acrobat.
February 15, 2006 at 10:03 am #164301gegsy
Cheers will do Jim
February 15, 2006 at 6:32 pm #164302maltheviking
If you are not aware, TDS 2006 is out. Connect have it in stock
Mal 😆
February 15, 2006 at 7:19 pm #164303gegsy
Cheers for the inputs.
I removed Adobe 7 and put Adobe 6 in………Voila all happy again.Cheers
February 15, 2006 at 8:48 pm #164304iadom
maltheviking wrote:If you are not aware, TDS 2006 is out. Connect have it in stock
Mal 😆
Do you have a part number for that ?
February 16, 2006 at 9:34 am #164305maltheviking
DVD version, Connect Product code no. …DSTDVD2006 £20 +vat
😆 MalFebruary 16, 2006 at 9:52 am #164306iadom
Thanks, oh horn’ed one.
February 18, 2006 at 9:45 pm #164307squadman
Adobe Acrobat Reader is most definately the problem when TDS goes t**s up. Ver 5 & 7 run fine as does Adobe Reader Professional, Ver 6 has a compatabilty issue with TDS or TDS has the issue.
February 18, 2006 at 9:46 pm #164308gegsy
Many thanks for the replies.
