TDS Disk
Viewing 15 posts - 1 through 15 (of 20 total)
  • #15628
    gegsy
    Is anyone else having problems with this disk>?
    When Its run it eventually the activex bar at top comes up and asks to download a file. Downloaded that and ram it does nothing with it.
    If you run it again the activex bar comes up again.
    PC has Win XP SP2 installed. Will run on laptop using ME, used to run on the XP one.
    Re: TDS Disk
    Is this the 2005 disc? I had this problem with it a while back and did a complete re install to cure. I’m on XP and have both Acrobat 7 & Acrobat 5 from the TDS disc on my system, most of the time it runs OK.
    #164296
    gegsy
    Re: TDS Disk
    Thanks Jim
    It the office thats havin the problem will check tomorrow
    Thanks Jim and for email 😉
    Re: TDS Disk
    If I remember I also stopped Acrobat from searching for, or downloading updates. I seem to remember it was the last update to Acrobat 7 that caused the problem. you may need to roll back system restore if you have allowed Acrobat 7 to update.
    #164298
    gegsy
    Re: TDS Disk
    Chers again will try that 😉
    gegsy
    Re: TDS Disk
    Hi Jim
    Its TDS Offline GB2004 (DVD)
    DGS-TDS-N 01/2004
    Cheers
    Re: TDS Disk
    Hi Greg, mine is version 2005, I am now almost sure the problem you have occured on mine as soon as I allowed Acrobat to update itself a few months back, I even posted on here at the time and others had a similar problem. Mine is now working fine after un installing TDS, Acrobat 5 & 7 doing a registry clean up, then re installing everything.
    Just make sure that you un tick the auto update/update promt options in Acrobat.
    #164301
    gegsy
    Re: TDS Disk
    Cheers will do Jim
    maltheviking
    Re: TDS Disk
    If you are not aware, TDS 2006 is out. Connect have it in stock
    Mal 😆
    #164303
    gegsy
    Re: TDS Disk
    Cheers for the inputs.
    I removed Adobe 7 and put Adobe 6 in………Voila all happy again.
    Cheers
    Re: TDS Disk
    maltheviking wrote:If you are not aware, TDS 2006 is out. Connect have it in stock
    Mal 😆
    Do you have a part number for that ?
    #164305
    maltheviking
    Re: TDS Disk
    DVD version, Connect Product code no. …DSTDVD2006 £20 +vat
    😆 Mal
    #164306
    Re: TDS Disk
    Thanks, oh horn’ed one.
    #164307
    squadman
    Re: TDS Disk
    Adobe Acrobat Reader is most definately the problem when TDS goes t**s up. Ver 5 & 7 run fine as does Adobe Reader Professional, Ver 6 has a compatabilty issue with TDS or TDS has the issue.
    #164308
    gegsy
    Re: TDS Disk
    Many thanks for the replies.
