Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › TDS offline disc
- This topic has 13 replies, 6 voices, and was last updated 19 years, 8 months ago by
effzedarr.
July 26, 2006 at 4:01 pm #19452
effzedarr
ParticipantHi folks anybody out there know where I can get another copy of the TDS/Electolux disc as my copy has now decided to not always show some sections, must annoying!!!!!!!
Cheers Effzedarr….July 26, 2006 at 4:15 pm #183151Dave_Conway
ParticipantRe: TDS online disc
I have one new copy of the 2005 disk (with a cracked case) you can have cheap 😉
You can order a new 2006 disk on part number 506006065003 as well from most of the wholesalers, should be about £25 🙂
July 27, 2006 at 4:38 pm #183152effzedarr
cheers,will ask the boss to get his purse out. 😆 😆 😆
many thanx Chris…July 27, 2006 at 8:05 pm #183153iadom
ModeratorRe: TDS online disc
Have you tried uninstalling then reinstalling the whole thing including Acrobat Reader 5, if you have Acrobat 7 as well as the Acrobat Version 5 that TDS insist on using then you can often get the very problems you describe.
July 31, 2006 at 4:27 pm #183154effzedarr
Cheers will have a go, fingers crossed, it’ll work….
Chris.August 16, 2006 at 12:37 pm #183155eastlmark
Installed the new 2006 v2 yesterday. Good news is that it uses neither IE (so it now doesnt trigger pop up blockers when closing) or Adobe 5 any more! Runs and comes with Adobe 7.
Also, those of you with pro corner access, there is now a heap of service info on there rather than just parts info as before.August 16, 2006 at 3:51 pm #183156iadom
Is the part number still the same Mark ?
August 16, 2006 at 3:58 pm #183157Dave_Conway
ParticipantRe: TDS offline disc
Yep, it’s still 506006065003 🙂
I’ve changed the title as well 😉
August 16, 2006 at 4:47 pm #183158effzedarr
Thanx lads just need to get the new PC up & running, more expence 🙁
once again cheers chaps. Chris…August 16, 2006 at 6:00 pm #183159mbdas
Hi my TDS2006 has packed up so I thought i would order another but that part number for connections and masterpart now says NLA or obsulete 😥
September 20, 2006 at 9:25 am #183160effzedarr
Does anybody know if this disc has a time out software on it ,ie will it still work next year etc!
cheers Chris… 8)September 20, 2006 at 12:20 pm #183161Martin
effzedarr wrote:Does anybody know if this disc has a time out software on it
Funnily enough yes it has 🙁
But if you copy the disc first then load that copy, it doesn’t 😀
September 20, 2006 at 6:04 pm #183162effzedarr
Hmmmm very interesting, worth knowing.
thanx for that Martin, cheers Chris.. 8)September 20, 2006 at 7:41 pm #183163mbdas
O 😳 I got my TDS disc to work in the end by unistalling it and then down loading Adobe 5 now works a dream again . I think I read about it somewhere 😉
Mark 🙂
