TEBA built-in hob gas control knobs
Home Forums Public Support Forums Spare Parts Help TEBA built-in hob gas control knobs
  • #8433
    Hi.
    Do you know where I can order gas control knobs for a Teba built-in gas hob. I have tried for hours on the internet to find them.
    Annette
    #128624
    Re: TEBA built-in hob gas control knobs
    There is a TEBA agent who is a trade member of this site – hangfire and he’ll get in touch. In the meantime please post up the model number and colour of the hob.
    BobHope
    good advice Mr P.
    the rating plate is located on the botom of the hob so not always the easiest place to get to, if you do the number with GB in the middle will be of great help, failing that can you post up a picture of the hob.
    Cheers Bob.
    #128626
    Thanks for that Penguin.. :rotfl:
    As for the control knobs what is the actual problem ?.
    Is it that they do not stay on or are loose or dont turn the gas on or off ?
    The knobs themselves are reliable but there is a spring clip that does come out and cause this fault.
    Send me a E-mail to r600a@hotmail.com and i’ll send you some out.
    bryan :wave:
    #128627
    Thanks so much for your reply. The model of the hob is GH60 (TOA21).
    A gas maintanence guy did come around once and tried to put them on and he said that there is normally a little tiny latch that will hook under the springs that is broken and that is what keeps the control on. Do you know if I would be able to purchase this model replacement knobs and how much approximately they cost?
    Thanks so much for your help
    Annette
    #128628
    Dave_Conway
    TOA21 isn’t the complete model Annette, it will have GB/?? on the end, the last two numbers are important.
    If you can’t find it, what colour are the knobs ?
