teba oven 10GBR34 SOS60SS
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts teba oven 10GBR34 SOS60SS
  • #66023
    rocker
    looking for the base element & twin grill element.
    please John
    #362763
    Re: teba oven 10GBR34 SOS60SS
    They are or should e available from the ukw shop. If not I’ve still got a few.
    Bryan
    #362764
    rocker
    Bryan, can you give me a price for both elements inc del, so I can quote to customer, I will buy from you.
    my email ableappliances@gmail.com
    john
    #362765
    OK
    Its a 2003 unit purchased from curry’s. Both elements are centre fixings and should be a 600mm unit in brown.Am i correct ?
    If so I will check tomorrow morning.
    Bryan
    #362766
    rocker
    bryan, connect has the grill element part No 5031680667332
    but not the base element…the one you discribe dosent sound correct
    john
    #362767
    Hi John
    Which one doesn’t sound correct ? Grill element being centre fixing which is the part number that you’ve given. or the base element which should also be centre fixing if it’s a TFA10GBR34 (which is the grill element part number you’ve supplied) as you’ve not got the full model number I can only guess and the only model listed or ever made by TEBA (unless my complete drawings from the TEBA factory are incorrect) with 10GBR34 is as I’ve stated a TFA model.And as there is a pre 2003 model the elements are the same carried over
    Bryan
