Teba SOF60 built in oven – faulty element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Teba SOF60 built in oven – faulty element
  • #10278
    asacardiff
    My wife turned the oven on today and the power to the downstairs tripped. When she reset the power and tried the oven it didn’t heat up. The grill works fine and I replaced the oven element after a similar incident just over a year ago. Do I need to buy a replacement oven element or is there a reset button or something? If I need to replace the element could someone tell me why this has happened twice in just over a year. I thought oven elements had a life of between 5 and 7 years!
    #139307
    litlor
    Re: Teba SOF60 built in oven – faulty element
    This a common fault fan element going down to earth and tripping electrics poss fan not running correctly (not fast enough) and element overheating
    #139308
    asacardiff
    Thanks litlor
    Do I need to buy a new element? If so I might consider replacing the built in oven & hob as £40 for an element is a little pricey.
    #139309
    Dave_Conway
    £40 ?? Where did that price come from, more like half that.
    Can you find the rating plate please and post the full model number (it will have GB in it).
    Probably something like SOF60GB????
    #139310
    asacardiff
    Hi Dave
    The full model number is SOF60G (TFA40-31Y).
    If I need a new element can you let me know the cheapest place to get one from and what I should do to prevent this from happening again.
    Thanks for your help
    Asa
    #139311
    hi
    dave its the standard fan element and single centre fixing grill element.
    bryan
    #139312
    asacardiff
    Can anyone tell me how to prevent this from happening again?
    Asa
    #139313
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=103
    Should explain why they all fail eventually………
    Bryan
    Well done Penguin , an excellent and informative article indeed. :tup:
    Bryan
    #139315
    asacardiff
    Thanks everyone for your help, much appreciated.
    New element fitted, oven cleaned, fingers crossed!
    Asa
    #139316
    I have an Arrow (Teba) P/N F09001GB53 made for B&Q.
    The same problem as above occured and I replaced the element; however, there is now no indication of power to the unit (trips checked etc.).
    I’m not sure if this is a common occurance, but I don’t want to fork out +300 pounds for another.
    I would appreciate any help.
    #139317
    Dave_Conway
    Check the fuse at the spur/switch the cooker is connected to if you haven’t already done so 😉
    Quite often these built in ovens are just either plugged in or connected to 13A fused spurs.
    Isolate the power 1st please :zap:
